Announcements
problems with installation
efren_tap
efren_tap
Good afternoon, could someone help me with an error that occurs to me when I now want to install Autocad 2024. It tells me "Insert th" to save in the web version and for mobile devices of Autodesk 'Disk and click Ok.
If I click Ok it gives me an error.
mdavis22569
Have you seen the following:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/open-save-to-web-m...
How are you installing the AutoCAD?    Autodesk Access or from a download?
Mike Davis
Hotter_R
Autodesk Support
Autodesk Support
Hi @efren_tap
can you please use the Autodesk Log collection tool and make the zip file available here?
Or send med a private message where to download.
With that logs, I can check for the problem of your installation.
Rainer Hotter
Technical Support Specialist - Installation & Licensing
