ObjectARX wizard 2019 installs, but doesn't do anything?
madpanda
Message 1 of 8
madpanda
I have VS Community 2017,  And when I go to "Visual C++\Autodesk" ObjectARX/DBX Project and ObjectARX/DBX/OMF Project populate in the selection tab, but when I click on either one and press "OK" Then New Project window minimizes and maximizes and nothing else happens. I can't continue. Anyone else have this issue?
Replies (7)
Message 2 of 8
moogalm
Autodesk Support
Autodesk Support
Hope you are working on Windows 10 ?, I have just checked on VS Community, it works for me the wizards.
Can you please go to this location-
C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\vcprojects\Autodesk
You 'll find "ArxAppWiz.vsz", Open with any Ascii editor like Notepad ++, please paste the contents here.
I'm happy to help you.
Message 3 of 8
madpanda
Hi, this is what my "C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\vcprojects\Autodesk\ArxAppWiz.vsz" looks like
VSWIZARD 7.0
Wizard=VsWizard.VsWizardEngine.15.0
Param="WIZARD_NAME = ArxAppWiz"
Param="ABSOLUTE_PATH = [TARGETDIR]ArxAppWiz"
Param="FALLBACK_LCID = 1033"
Message 4 of 8
moogalm
Autodesk Support
Autodesk Support
Thanks for information,
Please install with admin privileges.
  1. Uninstall Wizard
  2. Launch Command Prompt with Administrator Mode
  3. msiexec /i <wizard.msi>
Message 5 of 8
madpanda
That worked, I also uninstalled the .net wizards which won't install normally because they require .net 4.7
Message 6 of 8
moogalm
Autodesk Support
Autodesk Support
Yes, minimum .NET 4.7 framework is required.
Message 7 of 8
bwang-tecoustics
I got the same issue here. Though I tried <msiexec.exe /i "Fobjectarxwizard2019.msi">, I still can't start an Arx project from the wizard. I have .Net 4.7.2 framework. Would this cause the problem? I have issues with the .Net wizard before but solved followed the direction in this post: cannot-install-autocad-2019-net-wizard
Message 8 of 8
bwang-tecoustics
Sorry, I missed "Launch Command Prompt with Administrator Mode".  Finally it worked. I have to get to the Windows/system32 folder and run the cmd.exe as admin.
Thank you very much.
