not installing
not installing
Message 1 of 8
not installing
Hi
i have a problem installing autocad 2016 to my laptop
after downloading , i click open...
it did extract the files...
but it stop at the screen whereby it say setup initialization..
it been initializing for the past 10 plus mins.. i wonder why...
pls advise..
thanks
May
Replies (7)
Message 2 of 8
Alexander.Rivilis
You can try using Autodesk Virtual Agent in order to download and install AutoCAD 2016.
Instruction:  Installing Autodesk products from the Virtual Agent
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 8
i recd another error msg after i click install...
pls see attached..
thanks
Message 4 of 8
Alexander.Rivilis
Did you downloaded full AutoCAD installation package as I've proposed above (using Autodesk Virtual Agent) ?
If you do not do what I suggest - I can not help you.
Expert Elite Member
Message 5 of 8
hi
i had try to install from the virtual agent
is it a trial version?as it prompt me for product key and serial nos
thanks
Message 6 of 8
Alexander.Rivilis
It is universal version:
1. without Serial number and Product Key - it will be trial.
2. with educational Serial Number and Product Key - it will be educational version
3. with commercial Serial Number and Product Key - it will be commercial version
Are you a member of Eductional Community? If so you can get your Serial Number and Product key here:
How to Find Serial Numbers and Product Keys for Educational Licenses
So check your Autodesk Account:
Finding Serial Numbers and Product Keys
Expert Elite Member
Message 7 of 8
natasha.l
Hello @Anonymous,
Please let us know if this issue has been resolved by using the Autodesk Virtual Agent and locating your Serial Number and Product key through your Autodesk Account.
Message 8 of 8
Hi
thanks alot....after trying to reinstall.. and the serial nos provided..autocad is installed alreadythanks
may
