LTU Issue
LTU Issue
LTU Issue
sign key will be not highlight in license transfer utility when i want to export my license.
Otto
Hello sanket and welcome to the Autodesk community!
It looks like you are experiencing issues with the License Transfer Utility. The following article(s) should help you resolve the problem:
License Transfer Utility Overview
Using the License Transfer Utility to Transfer Licenses Online
Online License Transfer FAQ
Product Reactivation FAQ
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
TravisNave
The LTU works less than never.
Why do you need to export your license?  You're allowed a second activation, so if you are just moving it to another computer or are retiring an old computer, just reactivate it.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
