公告
Installing Error 1935
不适用
2,806 次查看
4 条回复
1 条消息(共 5 条)
不适用
i´ve a Problem to install Design Review 2018 on my Dell XPS 15 Notebook with Windows 10 Operation System, 16 GB RAM, 512 GB SSD Disk.
Errorcode 1935: During Installation .... assamblies components ... (please see attatchments)
i tryed installation direct form internet
i tryed Installation from a local disk
i tryed Installation with Administrator selection
Any idea why Installation run on error?
hermann
0 个赞
2,807 次查看
4 条回复
回复 (4)
2 条消息(共 5 条)
pendean
Community Legend
Community Legend
The errors are:
Rollback DirectX Runtime Failed Failure is ignored, Result=1619
Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
First, update your Win10, then update your video card drivers.
Second, empty your Windows Log-in Temp folder. leave it open and visible.
Third, Go into Win10's Settings, Apps section, select and uninstall versions of Visual C++ 2010 and 2012
and finally, try installing your software one more time.
0 个赞
3 条消息(共 5 条)
不适用
hi pendean,
sorry but your Workaround Ends in same Errorcode! Windows, Video Card, BIOS of XPS Notebook are up to date. All Temp Directories were cleared (C:\Windows\Temp\ and ...\AppData\Local\Temp), C++ Software has been uninstalled and endpoint Protection was disabled!
do you have another solution for my Problem?
Hermann
0 个赞
4 条消息(共 5 条)
不适用
Solution for my Problem:
I had to set the notebook to factory default! After Windows 10 Prof was installed DesignReview2018 could installed without any Troubles!
Thank
Hermann
5 条消息(共 5 条)
Martin.vanecek
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Error...
Works for me !no setup! msi file (ADR xxx.EXE package rename to xxx.ZIP and extract to new folder)
0 个赞
