Installation Error: "1: 5 2: Failed to load FNP_ACT_InstallerCA.dll. 3: 5"
Message 1 of 16
I have been unable to install any Autodesk products on two different Win 8.1 x64 systems due to the dll-error referenced in the subject. Is this a known issue/is there a fix?
Thanks!
Replies (15)
Message 2 of 16
TravisNave
Are you disabling anti-virus, UAC, and installing with local admin rights?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 16
Yes on all fronts. I've tried the web-installer and also the full browser download methods.
Thanks!
-Eric
Message 4 of 16
david.lau
Can you try this:
http://upandready.typepad.com/up_and_ready/2014/01/error-1-5-2-adlmpitsetproductinformation-failed-3...
Can you attach a screen capture?
David Lau
Message 5 of 16
Enabling full permissions to "Everyone" in "C:\ProgramData\Autodesk\Adlm" fixed the issue. Many thanks!!
-Eric
Message 6 of 16
Flexcut
I have the same problem with Building Suite 2017
Enabling full permissions to "Everyone" in "C:\ProgramData\Autodesk\Adlm" does not work.
What can I do for this problem?
See the screen capture
TKS
Angelo
Message 7 of 16
Flexcut
this is the log file
Angelo
Message 8 of 16
vv_t
Community Visitor
Community Visitor
Have you finde solution for the problem? The same problem and no solution.
Only pirate portable copy 🙂
Message 9 of 16
Adding full permissions did not work for me either. Any other solutions?
Error message from log file is MSI (s) (9C!FC) [13:50:00:462]: Product: ACAD Private -- 1: 5 2: ERROR : Failed to load FNP_ACT_InstallerCA.dll. 3: 5
Message 10 of 16
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
How are you installing your product?  Can you provide the setup.log file instead?  Make sure to remove any sensitive info like your serial # from the log before you post.
Mark Lancaster
Message 11 of 16
I'm installing from a web browser download. Although I've tried the online installer as well with the same error message.
  • UAC is disabled
  • Antivirus (Windows Defender) disabled
  • Added full permissions and ownership to C:\ProgramData\Autodesk
log attached.
Message 12 of 16
Mark.Lancaster
That's not the log I need.  It should have setup in the name
Update:  Also did you review this article and the solution it provides?
Mark Lancaster
Message 13 of 16
attached setup log
Message 14 of 16
I did review that article. It did not work either.
  1. The only file of that name was in the appdata\local\temp directory which gets overwritten; I did replace it though.
  2. No other location contains that file.
You did receive the correct log file yes?
Message 15 of 16
Any updates or suggestions?
Message 16 of 16
I was able to successfully install. I had to replace the Intel SSD with a Western Digital SSD then reinstall Windows 10 fresh. The first thing I did before any updates or drivers was install Autocad 2017 and it installed successfully.
Bad SSD? not sure, but it certainly suggests that.
