FATAL ERROR: Unhandled e0434352h Exception at 4DD74F99h
aguinn7E7D8
aguinn7E7D8
Getting this error when trying to launch the DWG Trueview app
I have done a clean install, still gives me the error.
-Alex
TravisNave
These are most often caused by Microsoft .NET Framework problems.  .NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
