error application 3ds Max
I have 3ds Max (installation complete) on my laptop and when I want to open it I have the window but also a error application message "An error has occurred and the application will now close. Do you want to attempt to save a copy of the current scene?" and then all closed.
Can you help me?
Charlotte Bapst
[email protected]
TravisNave
What is your video card and driver? That is probably the most likely
reason for the crash.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
