Error 101 installing Revit 2023 .1 Update
Consultant Consultant
Message 1 of 25
C: drive has over 50GB available
Installation File is downloaded and executed locally.
I have never had problems installing other Autodesk updates on this computer.
Search for a solution yields no useful results
Any suggestions? Thanks.
Accepted solutions (4)
Replies (24)
Message 2 of 25
DarrenP
might have to uninstall/reinstall
thats all i am finding to fix these errors
DarrenP
Message 3 of 25
pendean
Community Legend
Community Legend
You're not the first REVIT user that cannot install the 2023.1 update in these forums my friend today: seems to be an issue that needs to be escalated out of these forums to program managers.
Message 4 of 25
mdavis22569
That's the 2nd ticket in the last hour I've seen.
One I helped, it installed, errored 101 and is still in the Autodesk Desktop app.
Wondering if it's in part the outage
Mike Davis
Message 5 of 25
Thanos603
The cause of this error is unclear but hopefully we can identify it by reviewing the install log files.  Could you collect the following files into a zip file and post them for review?
From the Windows temp folder:
RevitUnitSchemas_2023_install.log
FormIt360Converter_2023_install.log
GenerativeDesignRevitInstaller_2023_install.log
RVTSP5_2023_{7346B4A0-2300-0510-0000-705C0D862004}_install.log
PACR_2023_install.log
REX Framework_2023_install.log
RVTCPSTLCON_2023_install.log
RCLCRVT_2023_install.log
From the C:\Users\michnitadmin\AppData\Local\Autodesk\ODIS folder:
Install.log
Summary.log
Tony Michniewicz
Autodesk Delivery Engineer
Anthony Michniewicz
Principal QA Analyst
Message 6 of 25
mdavis22569
From what I've seen / observed so far
I think it's in part due to the Autodesk outage. It's getting installed via the desktop app.
That's only where I'm seeing it vs downloading it from the Account manager ( currently )
Mike Davis
Message 7 of 25
Attached is the ZIP file.  A couple of the log files don't exist.
Message 8 of 25
I am getting the same 101 error installing it via Desktop App yesterday (the reason I downloaded the installation file to run it locally) and again just now.  I will try it tomorrow.
Message 9 of 25
Thanos603
The log files did not provide a clear answer so it might be wise to collect the full set of log files using the collection tool https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-U....
Additionally, could you check the Windows Add/Remove Programs list and report the version of Autodesk Identity Manager?
Tony Michniewicz
Anthony Michniewicz
Message 10 of 25
File attached.  Thanks.
Message 11 of 25
Thanos603
After further investigation, we believe the root of this problem is a newer version of Autodesk Identity Manager being installed.  If you have a version greater than 1.2.77.0, uninstalling it should allow the Revit 2023.1 Update to complete successfully.
Tony Michniewicz
Anthony Michniewicz
Message 12 of 25
Tony Michniewicz
Am I running any into troubles with other Autodesk programs if I do it?  This warning is not exactly encouraging.
Message 13 of 25
Thanos603
While the warning is serious, it should not be a problem as the installation of the Revit 2023.1 Update includes an earlier version of the Autodesk Identity Manager.  So you are only temporarily removing this component before replacing it with a version that is known to work with shipping versions of Autodesk products.
Tony Michniewicz
Anthony Michniewicz
Message 14 of 25
jaroslav.pancocha
Just to confirm, that uninstall of Autodesk Identity Manager works well for Revit 2023.1 update. Update installed succesfully.
Message 15 of 25
studio
the same error to me... it seems installer is searching a RVT.MSI in a temp folder, but no way...
impossible to install on my main PC with windows 11; at home, with 10 non problems
this time error 1612
Message 16 of 25
mdavis22569
Seeing about 4-5 tickets a day for this.   Most don't have the RVT.MSI in the C:/Autodesk ..
Downloading and extracting the installer tends to help resolve it.
However I do believe there is an issue ( issues within the installer itself and probably should get pulled and reviewed)
Mike Davis
Message 17 of 25
studio
no, i have uninstalled e reinstalled Revit, the problem remain
Message 18 of 25
mdavis22569
The missing RVT or Error 101
 if 101, look at the following option
Tony Michniewicz
Mike Davis
Message 19 of 25
bhorst
Removing Identity Manager first solved the problem for me - thanks for the tip Antony!
Message 20 of 25
dtiemeyer
Anthony,
I have 100+ computers to uninstall this so I can install the Revit 2023.1.1 service pack.   When I pull up the help for the .\AdskIdentityManager\Unistall.exe it does not list any switches for 'quiet'. Similarly, I cannot find a msiexec code to forcibly uninstall it. How can I automate the uninstall of this?
It always throws this dialog box:
My other CAD is a Cadillac and I like to Revit to the Max!
