第 1 条消息(共 108 条)
Cannot create deployment Revit 2021
Hi guys,
I am trying to create a deployment for Revit to be installed through SCCM. I just downloaded Revit 2021 and it came with 6 different files, I ran the executable to combine those into an installation file with setup.exe. I then run the Setup.exe to try to create deployment as I have done with AutoCAD, Inventor and Architecture. But, after running Setup.exe, it does not give me the option to create deployment, all I could do is a normal install as if I was going to install into that one particular machine. Have you guys seen run into anything like this with Revit 2021? or know a way to create deployment for Revit 2021?
Please let me know if you have any questions.
Thank you,
Nhan
