Hello everybody,
we bought a brand new version of revit 2021 and wand to build a software package for it. Now I have a little problem with the install parameters. According to this FAQ site: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/CloudHelp/cloudhelp/2021/... I used the parameters I want to use.
/t /q /w /language de-de /c RVT: INSTALLDIR="%PROGRAMFILES%\Autodesk" ADLM_EULA_COUNTRY=DE INSTALLLEVEL=5
In my opinon the installation should start silent and set the install path and eula and so on. But nothing happens. The installation starts, I have to accept the EULA select the install path and so on. I tryed it with powershell directly.
It seems that all parameters will be ignored. Someone has an idea? I use the setup.exe from the first folder.
Thank you 🙂
