can not install OS: macos high Sierra
justmecn
Message 1 of 42
justmecn
Replies (41)
Message 21 of 42
Message 22 of 42
Message 23 of 42
spoelstra123
Community Visitor
Community Visitor
Honestly, STFU and remove the filesystem check and let us use the software we paid thousands of ****ing dollars for, or you'll loose all your customers.
Message 24 of 42
Doesn't work.
Message 25 of 42
The script that checks the system file type is "chkfs", which has the call defined in the "Distribution" file. The "chkfs" is a shell script that you can edit, so I changed it to allow the installation.
To do the editing, simply unpackage the pkg file with pkgutil and then repackage and install normally (refs: https://coolaj86.com/articles/how-to-unpackage-and-repackage-pkg-osx.html )
My changes: I commented the statement that checks the file system type. See below.
So, see it running in the high sierra.
Until a version that corrects the "bug" for the new Apple system is released, you may be able to use AutoCAD.
Message 26 of 42
Awesome, thanks for sharing your work!
Message 27 of 42
There's even no need to comment anything in a script itself
You can just edit Distribution file, changing
function verifyFileSystem()
            system.log("Testing System Drive File System for compatibility with AutoCAD");
            var retcode = system.run("chkfs")
            system.log( retcode )
            if (retcode) { blablabla}
to
            if (0) { blablabla }
Message 28 of 42
Greetings.  I'm new here but I've been following the thread. High Sierra Update was officially released today. Has anyone heard any news about an Autocad update?  I've got High Sierra running on my macbook 2015 and Autocad wouldn't function after the update nor did it work after trying a full reinstall. Thanks ahead for the help.
Message 29 of 42
maxim_k
Welcome to Autodesk Forums!
Hi Jay,
The answer to your question is here:
https://forums.autodesk.com/t5/autocad-for-mac-forum/macos-high-sierra-compatibility/td-p/7406988
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 30 of 42
Thanks for your help and quick reply Maxim.
Message 31 of 42
maxim_k
Jay,
The topic I referred in my previous post were updated: the Update for AutoCAD 2017 for Mac which fixes compatibility issues with macOS High Sierra has been released:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 32 of 42
maxim_k
Hi all!
Updates are available for AutoCAD for Mac 2017 and AutoCAD LT for Mac 2017 to enable compatibility with High Sierra and to to increase performance.
The full update of AutoCAD for Mac 2017.2 can be found here
The full update of AutoCAD LT  for Mac 2017.2 can be found here
The patch for  AutoCAD for Mac 2017.2 can be found here
The patch for  AutoCAD LT  for Mac 2017.2 can be found here
Readme file is here:
http://up.autodesk.com/2017/ACDMAC/AutoCAD_and_AutoCAD_LT_For_Mac_2017.2_Update_Readme_ENU.htm
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 33 of 42
Hi Max,
Just letting you know that I just installed the full update and it went flawlessly. I'm back up and running!
Thanks for all the help.
Message 34 of 42
As the New macos High sierra has come,
can we now run Autocad for mac 2017 on it ??
Please confirm as Apple APFS would have some issue ?
Message 35 of 42
maxim_k
Please look here:
https://forums.autodesk.com/t5/installation-licensing/can-not-install-os-macos-high-sierra/m-p/74082...
Update for AutoCAD 2017 (full and LT) is already available.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 36 of 42
So is it possible to install AutoCAD 2015 on High Sierra?
Message 37 of 42
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
Only version AutoCAD or Acad LT For Mac version 2017.2 is able to be installed on this version of MAC OS.
Mark Lancaster
Message 38 of 42
@Mark.Lancaster
thanks for the quick answer. Actually Im a student and I using AutoCad for my masters. So I only allowed to download AutoCAD 15 as a Mac version. Do u have any idea to get AutoCAD?
Message 39 of 42
Mark.Lancaster
@Anonymous
I'm confused..  You have access to AutoCAD for Mac so why are asking how to download it.  Are you asking for the 2017 version and requesting it?
Mark Lancaster
Message 40 of 42
@Mark.Lancaster
sry for miss hitting the key, I mean 2017.
Actually I can't install the 2017 Version for Mac. Bildschirmfoto 2017-10-19 um 13.16.18.png
sry for my bad English.
lets do it the easy way. is their a possibility to install the 2017 version for Mac on high Sierra?
