can not install OS: macos high Sierra
justmecn
Message 1 of 42
justmecn
Replies (41)
Message 2 of 42
maxim_k
Welcome to Autodesk Forums!
Hi Justme,
AutoCAD for Mac is not designed to be installed and run on APFS file system.
As the alert states, it can be I installed only on HFS+ file system.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 42
pendean
Community Legend
Community Legend
I suspect the OP may not know what that means @Anonymous_k ... .
Message 4 of 42
maxim_k
OK,
in other words:
Current version of AutoCAD for Mac (2017) is not designed to run on macOS High Sierra, especially on the first beta version of this new OS.
APFS is the new file system from Apple introduced in iOS 10.3 and macOS High Sierra also uses this file system too.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 42
justmecn
but all the other app can install, and they were old version.
I don't think it's because of APFS.
Message 6 of 42
maxim_k
I also think that AutoCAD can run on APFS volumes, but the restriction about file system type is hard coded inside AutoCAD installer, so only developers can change it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 42
justmecn
Thank you!I hope as soon as possible.
Message 8 of 42
Is Autodesk working on the topic?
Message 9 of 42
Hi!
Does anyone knows if there's any change about the compatibility between AutoCAD 201x and macOS 10.13 High Sierra?
Message 10 of 42
stephane_veireman
APFS compatible ?
Mac Studio M1 Max - 64 Go - 2 To - macOS Sonoma - AutoCAD LT 2024 for Mac
Message 11 of 42
Yep, that was my question!
Message 12 of 42
stephane_veireman
I've the same question...
Message 13 of 42
Any idea when Autodesk will update AutoCAD for Mac so that it CAN work with the new APFS? Seems like relatively high priority considering the upgrade rate on MacOS devices.
Message 14 of 42
Mark.Lancaster
@Anonymous
Welcome to the Autodesk User's Community..
This is a user based forum and we would not know what Autodesk is working on for the new MAC OS (until there's a formal announcement)..  I would assume the AutoCAD for MAC 2018 version will support that but there's no release date for this version.  Even if Autodesk employees knew, no one will indicate it until its time..  Smiley Wink
Mark Lancaster
Message 15 of 42
maxim_k
AutoCAD for Mac 2017.1 can run under latest Beta of macOS High Sierra with new APFS, but it need to be installed on Sierra (or El Capitan) before upgrading to High Sierra.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 16 of 42
Ok this is very disappointing.. I've finally bought a new Macbook to draw with Autocad 2017.. and I can't install the f*cking software..
Its not an option for me to erase my full harddrive, do a clean Sierra install, install Autocad 2017.1, and update to High Sierra..
What are the other options? Are there some people who've installed it manually or something? Or is there a patch so we can disguise that we're on HFS+ file system?
Message 17 of 42
maxim_k
Robert,
You should not use swear words in relation to the software that you intend to use.
Autodesk doesn't support its software on Beta versions of OS.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 18 of 42
oke, but wil it support when High Sierra is out of beta.. (in approximately 5 days)
Message 19 of 42
natasha.l
Hello @Anonymous,
As of right now, Autodesk does not support high Sierra which uses a new APFS file system. We do not support any Beta operating systems, when it is released we will have to wait & see if there are plans to support it in the future when Autodesk formally releases this information.
Thank you.
Message 20 of 42
And it STILL doesn't work...
