Black display with no objects showing
I just downloaded AutoCAD 2019 and I am not seeing any display on any of the tabs. When  I draw a line, it shows the dimensions of the line, but there is no rendering of the line and my whole display is completely black. I also imported an .dxf file and had the same issue.
What would be the cause of this issue? Should I download a different version of AutoCAD?
Chris
TravisNave
What is your video card and driver version?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
