Autodesk Desktop App not Installation error
HayMar
HayMar
I'm updating for my Autodesk applications (Revit,Autocad,Navisworks etc.) through the Autodesk desktop app ,but it is seen getting error to installation. I have screen capture and attached it.
mdavis22569
Hi @HayMar
Can you share a screenshot of the error message?
Are you trying to install it on it's own or with a Product install?
Have you reviewed the following AKN article:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Install-Autodesk-Desktop...
Mike Davis
HayMar
@mdavis22569  here is my screencasts attached.
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Install-Autodesk-Desktop... here I can't find AdAppMgrUpdater.exe from step 3 yet. I can skip it and process uninstallation?
mdavis22569
not attached ...
Skip that step and let's see where it goes from there
Mike Davis
HayMar
mdavis22569
So it's a Revit install error now the Desktop App itself.
So let's do this:
Clean out the %temp% folder. Reboot ... don't start any software and then try the update
Mike Davis
