AutoCAD Activation
AutoCAD Activation
Message 1 of 10
AutoCAD Activation
I am having difficulties getting AutoCAD to run. It opens, but closes abruptly while on the splash screen, Launching the trial works, but once activated, it begins crashing. See files here:
https://onedrive.live.com/redir?resid=9B606F15149592F9!13780&authkey=!AAqLC_E8WSWElCA&ithint=folder%...
Replies (9)
Message 2 of 10
david.lau
I would unintall the software, reboot and re-install it.
I would set the following before re-installing the software:
http://upandready.typepad.com/up_and_ready/2013/04/quick-start-general-installation-workflow.html\
Re-download the software using the instructions below:
http://knowledge.autodesk.com/customer-service/account-management/software-downloads/download-method...
David Lau
Message 3 of 10
Unfortunately I have already tried all of that twice, to no avail. For some reason it works on another computer it is installed on.
Message 4 of 10
jessica.t
Hi @Anonymous - Can you confirm that your machine meets the listed AutoCAD System Requirements? Thanks!
Jessica Thrasher
Message 5 of 10
Yes, it does. It's a Dell Precision M6500. 1920 X 1200 screen resolution, Intel Core i7 Extreme Edition @ 2.9 Ghz. 6 GB RAM, discrete graphics. It runs Inventor fine, so I see no reason why I can't run AutoCAD.
Message 6 of 10
ukdxb012
What version of AutoCAD is it? Have you also applied the latest Service Packs and finally have you tried Repairing the installation or Reinstalling from Add Remove Programs?
http://knowledge.autodesk.com/support/autocad/downloads
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Recomme...
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 7 of 10
It is AutoCAD Mechanical 2016. It was installed as as suite. I have tried a repair install, as well as a reinstall of both the entire suite and AutoCAD by itself. THere are no service packs that I am aware of out for it yet.
UPDATE: I tried the "VLX Hotfix" out for AutoCAD 2016, it had no effect on the problem.
Message 8 of 10
david.lau
Can you send me the log files located here:
C:\ProgramData\Autodesk\AdLM
You can zip them before uploading...
http://upandready.typepad.com/up_and_ready/2012/12/tip-send-to-compressed-folder.html
David Lau
Message 9 of 10
Please see the original post. THere is a link there to a OneDrive folder, containg a video of the problem and logs for both Inventor and AutoCAD Mechanical, for comparision. Inventor runs properly.
Message 10 of 10
SOLVED!
Even though the activation caused it, I had to reinstall my graphics driver after a BSOD, and that fixed it! I have an ATI FirePro M7820 if anyone finds this in the future having this problem. I simply used the automatic driver detector, and let it run.
