64bit licensing error -15.570.0
I am trying to install a license server on a Server 2012R2 that is running as a Domain Controller.  The LMUTILS show server up and running, and based on the threads here, I have disabled IPv6 and (at least temporarily) the Firewall on the domain network.  A PC conneced to domain cannot get the license and gets an error of -15.570.0.
What are my options?
As history..I had originally tried minitab on this server too, same issue, so I moved it to a File Server, where it works fine.  I tried putting AutoCad on the same server, where it worked, but promtply killed MiniTab (I regenrated license files for the different ethernet addresses).  I tried combining license files with no success and since we have more minitab users than AutoCad, left it running with Minitab,  now back to DC as alternate server and I am wondering if there are other services that need to be installed on DC for it to work as a license server?
Autodesk 3D Plant Suite 2014 is the product.  I have added the system variable for the new server, which pings correctly from the client and returns a IPv4 address now.
Otto
Hello sanjay.chadha and welcome to the Autodesk community!
It looks like you are seeing "Error 15" when registering and activating software or using the Portable License Utility. The following article(s) should help you resolve the problem:
Port numbers for single server FLEXlm setup
Problems registering and activating software or using the Portable License Utility
Checklist for troubleshooting Activation and Licensing issues
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
TravisNave
-15 is usually a firewall issue on ports 27000-27009 and/or 2080.  But it can also happen if you are running more than one license manager at the same time.  Since you are running Minitab, I would recommend that you combine these together on the 11.12 version of lmgrd so that the port selection does not kill the other process.
For the best method to properly combine your license managers, please read my entire thread here and choose the method that best fits your needs:
http://forums.autodesk.com/t5/Installation-Licensing/Combining-License-Files-for-Subscription-and-No...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Actually, the whole reason I put this on a DC was so that it would not be on the same server as Minitab, so it was just by itself.
Sanjay R Chadha | VP and Chief Information Officer
Melior Innovations, Inc
O: +1 713-652-9125
This e-mail is covered by the Electronic Communication Privacy Act, 18 U.S.C. Section 2510-2521 and may be legally privileged. If you have received this transmission in error, please notify the original sender immediately by return e-mail or by telephone at the telephone number provided above and delete/trash the original message from your system. Thank you for your assistance. The information contained herein is confidential information provided only for the use of the individual or entity for whom it was intended. If the reader of this message received it in error, is not the intended recipient, or if an attachment is made in error, the reader is hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited.
I never resolved what the issue was with DC, but I went back and revisited my installation on the File Server.  Turned out that Minitab was a 32 bit installation and AutiCad was 64 bit, which is why the adsk demeon would not run.  I got the 32 bit version and now it works.  Although, now I find that if I installed Auticad with an admin ID on a machine, it works for that ID, but if another user logs in, it does not work, so I suspect some entries are needed in the current user part of registry that must be missing.  On another machine, I took a different tactic, where I used a user login, and then elevated privileges, and that one seems to work.  Is there a procedure for doing the user specific installation for a machine that has AutoCad installed?
By the way, thanks for all the high quality posts you have on the forum.  They are outstanding.
Sanjay
