3ds Max 2019 not starting
koljohnkiri
Message 1 of 11
koljohnkiri
Double click the 3ds Max icon and i get a loading cursor for a slight second and then nothing. No splash and not in Task Manager either.
Have not had any problems using max over the last few months. Recent changes a day prior include replacing GPU and updating motherboard.
I have reinstalled max twice now, one of those times I completely wiped anything related to Autodesk and followed the Autodesk guide on a clean install.
My next option is most likely a reformat at this stage.
If anyone has come across this issue and has a fix it would be greatly appreciated.
Replies (10)
Message 2 of 11
leowarren34
Since you have replaced the gpu have you got the correct and up-to-date drivers for it?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 3 of 11
robBouch
Hello @koljohnkiri
Welcome to the community!
I would suggest that you update your graphic card driver, install all available Windows Updates, and install any Autodesk updates that are available in the Desktop App.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 4 of 11
leowarren34
Can you provide any more details in regards to hardware @koljohnkiri?
Leo Warren
Message 5 of 11
robBouch
Hello @koljohnkiri
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 6 of 11
koljohnkiri
Sorry for the late reply, I did the uninstall again including removing all files, though this time I removed Autodesk from registry and all is well.
Thanks for replies!
Message 7 of 11
koljohnkiri
So I uninstalled everything Autodesk related and removed Autodesk from Registry as well as any Autodesk related files. Reinstalled and worked fine.
2 days later it is once again not working. I did install a program yesterday which said something was missing from the visual C++ redist (at least something along those lines) and it installed something. So i think this whole problem is related to the C++ Redist.
Now ive followed the C++ Redist removal and re installation guide as well and that did nothing.
Message 8 of 11
koljohnkiri
i8700 K
Gigabyte Aorus Max 1080Ti
Asus Maximus X HERO
G.skill 3200 Ram
Samsung Evo 840 SSD
Message 9 of 11
koljohnkiri
Hi, this was the first thing I checked
Message 10 of 11
koljohnkiri
Okay, this is embarrassing, I had updated just about everything but windows main update, so I have been using a build which dates a few months old. I have no idea how I missed this and feel quite stupid considering the extent I went to.
Problem solved.
Message 11 of 11
leowarren34
Happy to know it is fixed, it is the little, unexpected things that catch us out..
Leo Warren
