Maya Licensing Rent
Maya Licensing Rent
andrewrbelcher
Maya Licensing Rent
andrewrbelcher
 Hey there! I am on the student version of Maya. I would want to use a professional license so I can post my animations online for people to be able to see. I am not using the pro version because well I can't afford it. I could, however, afford probably a month of it. Could I switch to a pro license for about a month and do some animations, post them, and go back to a student license?  Some places don't let you do that so I just wanted to check.
leowarren34
Yeah you can do it however it may be wise to use a separate account for the pro account, just remember to reset your licensing when you switch between accounts.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Mark.Lancaster
@andrewrbelcher
In addition to @leowarren34 information..  You should never mix commercial license product installation on the same machine as educational license.
Update:  One more thing I forgot to add.  Anything you created in an educational versions has to be recreated from scratch in a commercial license in order to be shared publicly or to make any profit.
Mark Lancaster
andrewrbelcher
Ok. Got it. Thanks. Just out of curiosity, what would happen if I did mix them?
Mark.Lancaster
@andrewrbelcher
Mixing commercial and educational license on the same machine could lead to fines if Autodesk audited you..
Mark Lancaster
andrewrbelcher
If I deleted the student version from my device could I get it? Or does it absolutely have to be a new device?
leowarren34
Yes technically you could but you'd need to clear every trace of your edu license which may be more hassel than it's worth...
Leo Warren
