Storyboard Improvements
  1. Allow rotation of titles or captions.
  2. Allow grip movement of titles or captions on screen, not just coding X,Y offsets in dialog box.
  3. Create settings for default font properties for titles and captions.
  4. Allow copy/paste of titles and captions instead of having to create a new on every time. This is annoying since we can’t set a default font!
  5. Create a format painter for titles/captions.
  6. Ability to create Labels that are Geo located to the model with ability to be static or able to orient toward the camera as it moves.
4 Comments
Eric_Chappell
It would be best if a list like this were sumbitted as individual ideas.  Having a singular, "bite-sized" approach makes these things much more doable from a development standpoint and eaiser to discuss and support from a community support standpoint.  As it is now, the development team has to consider all of these items at once and that makes fulfillment of this idea very challenging. Also, multiple ideas dillute and complicate the voting and discussion process.
I suggest that you re-post this as individual ideas - you'll have much better chance of getting support and acceptance from the user community and from Autodesk.
Eric_Chappell
Hi @KPerison, If you could break these up into individual ideas as requested, we can start moving them through validation and possibly acceptance and implementation.
Thanks!
scunningham
I'm going to mark this "Archived," which means the idea - or in this case, ideas - aren't being considered for implementation at this time.
That said, I did want to highlight something loosely related to one of the things on your list:  "The ability to create Labels that are Geo located to the model with ability to be static or able to orient toward the camera as it moves." In 2017.2 and .3 there were some changes to how things are labeled on some assets; these design guides that label or annotate key locations on a road or legal boundary do adjust based on you zoom, pan and rotate around the selected asset. While this isn't functionality specific to storyboards, I did want to point out the behavior does exist elsewhere in IW.
scunningham
Status changed to: Archived
