@Alina_Yusupova, can you try and start InfraWorks 360 with Administrator rights and see what happens then?
If that doesn't help, then I suggest deleting your Local Cache folder and download your Cloud version again.
You can try to recover the model first.
If that doesn't work, to expand on what @John_DeLeeuw mentioned about deleting your locally cached model.... to find your model's local cache location simply hover over the cloud icon, note the file location, close InfraWorks and delete that entire folder (the one the just numbers. In my case it was located in folder 112924).
Open InfraWorks again and re-download the cloud model.
Additional info about deleting the model can be found here: http://forums.autodesk.com/t5/infraworks-360-infratips/how-to-delete-an-infraworks-model/ba-p/590036...
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Hello @Alina_Yusupova
for unknown reason the "config" files in your model went corrupted. If you open it in a text editor you will see a number of cryptic symbols. It should be a text file.
You can replace the config files of your local model with those of your cloud model to be able to open the local model without errors.
A reconnection to/refreshing of each data source might be needed to load all data source information again.
Karsten
I opened my model (in home computer, than copied to computer in the work).
But now is problem - my model dont open in other computers. I must to send this to clients, but they cant open. I tried to send local model and to share cloud molel.
@Alina_Yusupova, you can share your Cloud model with clients without opening it. Check this page for the Collaboration workflow.
You just need to add your clients email address (that they used with their Autodesk ID) to the Model Group in which your InfraWorks 360 model is generated. Click Done to send an email invitation to each new user. A notice is displayed on InfraWorks 360 Home. Users must accept the invitation to join the group and download your model.
@Alina_Yusupova, then I suggest you duplicate your home model or the model version you are still able to open on any PC and publish/sync that again to the same Collaboration Group.
You can Duplicate an existing cloud model, which creates a local, disconnected copy of that model.
Hope this can help you?
Hello. I ve got the same problem. When try to open model from cloud, it starts to download and after 1% writes "Unable to open the model"
Tryied to re-instal 3 times, nothing helps. On my other computers everything is fine
I use 17.3.133.0 version.
Today i tried to reinstall and my installation process stops on Setup initialization. Firewall and antivirus disabled. Opened like admin
Hi @Alina_Yusupova,
were you able to make any progress, have you tried sharing the model with your clients (or on another computer) manually, and then open it through Infraworks.
Does it happen with every model?
Hi @tsausaky,
did it work?? Were you able to install IW and get it working?
Try this:
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
