As we spoke @htariq.bece17nice, I think the best way to do it is with one bridge and a large assembly if you're up to modeling one corridor. If you break it into two corridors in Civil 3D, InfraWorks will accept it better to add two bridges, one in each component road.
Cheers,
[PT-BR] Se essa postagem foi útil para você, clique em
Curtir! Se a resposta resolveu o seu problema, clique em
Aceitar Solução. [EN-US] If it was helpful to you, click on
Like! If the answer solved your problem, click on
Accept Solution. ![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
Matheus Lima Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager |
Instagram @bim_infra |
LinkedIn
