InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Two Bridges Close together
1 REPLY 1
htariq.bece17nice
236 Views, 1 Reply
I need to model two bridges that are close together as shown in the picture. I'm bringing corridor from c3d as shown.
1 REPLY 1
As we spoke @htariq.bece17nice, I think the best way to do it is with one bridge and a large assembly if you're up to modeling one corridor. If you break it into two corridors in Civil 3D, InfraWorks will accept it better to add two bridges, one in each component road.
Cheers,
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
Rail Community
