Hi @david.ure!
Well, I couldn't replicate the issue here. I think this is not a coordinate system issue. Is it possible to send the files? Or just the shapefile, here or via private message. I can test here if the same happens.
Is this happening in all transmission towers or just one? And just in case, is there any manual editing in InfraWorks or just the importation?
[PT-BR] Se essa postagem foi útil para você, clique em
Curtir! Se a resposta resolveu o seu problema, clique em
Aceitar Solução. [EN-US] If it was helpful to you, click on
Like! If the answer solved your problem, click on
Accept Solution. ![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
Matheus Lima Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager |
Instagram @bim_infra |
LinkedIn
