- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
See below workflow:
I have a linear structure done in Revit. The project base point is set based on known UTM coordinate system.
1) convert Revit to FBX.
2) import FBX to AIW-
3) configure file coordinate system to match project point base from Revit
4)set the rotation angle = 360 - 343.58( angle to true north)
The issue: The linear structure is not parallel with the ground features in AIW.
To make sure I got the coordinates right, I did an export of the linear structure from Revit to Civil 3D using the shared coordinate system and it looks .fine., the lines are parallel.
The problem is obviously the angle precision or conversion .
I have checked the units in Revit - angle is set in decimal degrees, In AIW the angle is set in "degrees".
Are there any other settings that I can adjust ?
See images below
