InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Roadside Grading
10 REPLIES 10
Message 1 of 11
oriole_phillips
930 Views, 10 Replies
Roadside Grading
This is not as useful as I thought. When a design road is created and Roadside Grading is used, the cut fill slopes are applied but no option is given to allow color to these slopes. The slopes are blended into the Terrain. In the real world, the client is usually looking for an impact of how the design road cut/fill slopes would affect the existing Right of Way.
Tags (2)
10 REPLIES 10
Message 2 of 11
in reply to: oriole_phillips
I totally agree Oriolep!
Why don't you ask for this idea to be implemented here?
https://forums.autodesk.com/t5/infraworks-360-ideas/idb-p/129/tab/most-recent
At your disposal for other information
Nick
Message 3 of 11
Matt__W
There's an idea posted in the IdeaStation about incorporating grading styles for roads. Being able to specify a particular grading style would give you the ability to define a color or some other material to indicate the extent of grading. Please vote it up for future product consideration.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 4 of 11
Hi @oriole_phillips,
In the meantime, you have a couple alternatest to accomplish this:
1. Create a coverage area over your grading [manually], and apply any available style, or create a new style to apply to these gradings.
2. Export an IMX and import to C3D. Create a simple corridor using the design details [align/profile], and create a top surface from the corridor. Import that C3D DWG, and you will have the option to import these daylight coverage areas. Apply the desired style.
Willy Campbell
Message 5 of 11
Matt__W
in reply to: Willy_Campbell
Jeez! I don't think I like the sound of that, @Willy_Campbell. It sounds a lot like.....*gasp!* WORK!!   😉
Matt Wunch
Twitter | LinkedIn
Message 6 of 11
Eduardo.Soethe
in reply to: Matt__W
Thanks @Matt__W for mention my "idea"!
I do like @Willy_Campbell, commented:
LandAreas
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
Autodesk Community
Message 7 of 11
How about using terrain themes while you apply roadside grading? Does this achieve a result you would be looking for?
https://forums.autodesk.com/t5/infraworks-360-infratips/use-terrain-themes-when-modifying-roadside-g...
Thanks!
Elliott
Principal Specialist, Infrastructure
Message 8 of 11
I am not trying to detail design here, only should a quick concept to a client. Infraworks falls short in this area to provide a quick visual of cut/fills for a design road.
Message 9 of 11
No this is not the situation in my design. Looking for areas of a specific grade such as only 2:1 or 50%.
Message 10 of 11
Not accurate and difficult to see where bottom of slope or top of slope is when the roadside grading is blended into the terrain.
Message 11 of 11
Yes I agree with you for this I have  put this Idea on Idea Station grading styles for roads, but I know in a few months we have a lot of changes on Infraworks and i hope we have this too!
Autodesk Community
Rail Community
