InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Model Builder Map broken
21 REPLIES 21
Message 1 of 22
andrew.stubbs
1821 Views, 21 Replies
When I open Model Builder, the mapping seems broken as shown in the picture attached. It appears this way for all mapping (satellite etc). A model can be created from this but it is difficult to determine the area while the map is broken. Anyone know of a solution?Capture.JPG
21 REPLIES 21
Message 2 of 22
Hi @andrew.stubbs
I have never seen that before, so don't have an immediate solution.
Can you send the InfraWorks log files? Maybe there is something logged.
Looks like a display or coordinate system issue.
Karsten
Karsten Saenger
Message 3 of 22
SethHall
in reply to: andrew.stubbs
Hi @andrew.stubbs
Could you please try the following and let me know if it helps?
  1. Close down InfraWorks
  2. Rename or delete the following folders:
    • C:\Users\<<User>>\AppData\Local\Autodesk\Autodesk InfraWorks\cache
    • C:\Users\<<User>>\AppData\Local\Autodesk\Autodesk InfraWorks\QtWebEngine
  3. Restart and try to access Model Builder.
Seth Hall
Product Owner
Model Builder
Message 4 of 22
Message 5 of 22
andrew.stubbs
in reply to: SethHall
Hi Seth,
I'll have to contact IT and ask them to delete the folders. I will come back to you when they have them deleted.
Message 6 of 22
andrew.stubbs
Worked perfectly Seth.
Is this something that should be done regularly?
Message 7 of 22
Hi @andrew.stubbs
it's the first time I heard/saw this issue.
The procedure is not something to be done on a regular base.
Karsten.
Karsten Saenger
Message 8 of 22
Estou com o mesmo problema. Fiz o que você indicou e não funcionou. Preciso de ajuda.
Message 9 of 22
Karsten.Saenger
Hi @Anonymous ,
can you please send the ful InfraWorks log files from path %appdata%\Autodesk\Autodesk InfraWorks\logs
C:\Users\<<USER>>\AppData\Roaming\Autodesk\Autodesk InfraWorks\logs ?
Karsten.
Karsten Saenger
Message 10 of 22
in reply to: Karsten.Saenger
Ok.
Message 11 of 22
Karsten.Saenger
Hi @Anonymous ,
thanks for the log file - I don't see any obvious error in the text.
Only thing is that you are using an Intel(R) HD Graphics 4600 adapter which could make problems with InfraWorks.
Can you first check if you have a second more powerful graphics adapter installed? If yes, set it up to be used with InfraWorks, instructions can be found here: http://knowledge.autodesk.com/article/How-to-force-your-laptop-to-Run-with-Graphics-Processor-vs-the-default-Integrated-Graphics-for-InfraWorks
Please also make sure that you have the latest graphics drivers installed.
Karsten.
Karsten Saenger
Message 12 of 22
Eu só tenho o adaptador gráfico Intel(R) HD Graphics 4600. Fiz a atualização da placa de vídeo, mas o problema ainda continua.
Message 13 of 22
Karsten.Saenger
Hi @Anonymous ,
do you have the chance to test another computer in the same network?
Karsten.
Karsten Saenger
Message 14 of 22
SethHall
@Anonymous
Could you browse to www.bing.com/maps and see if you have the same issue?
Seth Hall
Product Owner
Model Builder
Message 15 of 22
O site www.bing.com/maps está funcionando bem no meu computador.
Message 16 of 22
SethHall
@Anonymous
OK thanks. You mentioned you did these steps:
Did you ensure you closed InfraWorks before deleting the folders? They will not be regenerated if InfraWorks is still open.
Also, I would be curious to hear your answer to Karsten's question about another computer in the same network.
Seth Hall
Product Owner
Model Builder
Message 17 of 22
Reiniciei o computador, e fiz as etapas que você falou. O problema continua.
Ademais, instalei o Infraworks em outra máquina e na mesma rede, e o problema também ocorre nessa outra máquina. Acho que o problema deve ser na rede da empresa. Alguém sabe o que devo fazer?
Message 19 of 22
Hi, I have the same problem as @D.S.Curvello. My Infraworks is the 2020 version. Tried everything as told before but still have the maps broken at Model Builder. May you help me?
Message 20 of 22
SethHall
Hi @Anonymous
Could you take a screen shot of what you are seeing so I can understand what you are dealing with?
Also, I would recommend signing out of InfraWorks and signing back in, then launching Model Builder again.
Thanks!
Seth Hall
Product Owner
Model Builder
Rail Community
