Infraworks doesn't run
edgar.rey
Message 1 of 12
edgar.rey
Hello everyone. I'm preparing a class in which we'll be working with Infraworks. I downloaded version 2026 of the software and was working without any issues. However, when I tried to restart the software, it wouldn't run. The startup screen looks like the attached image.
I looked at the posts on this forum about this and found that the best thing to do is uninstall and reinstall the software. I did this, but it didn't work. I also uninstalled and installed version 2025, but that didn't work either.
I don't know what's going on, as I had previously worked fine with the application.
Please, any ideas on how to overcome this issue, I'd appreciate it.
Replies (11)
Message 2 of 12
ingjuan_mena
I'm experiencing the same issue since two days ago, today I downloaded the 2025 version and i t works, but the 2026 version still crashed
Message 3 of 12
edgar.rey
Thank you @ingjuan_mena for your reply. I uninstalled version 2025 and installed version 2024, but that didn't work either. This issue is unusual because version 2026, the first one I installed, worked for a short time, but then the second time I tried to launch the app, it stopped working.
Message 4 of 12
ingjuan_mena
Yes, I confirm that neither of my versions is working now. That's unusual,
it's never happened before to me.
Message 5 of 12
edgar.rey
My Infraworks version 2024 was working well for a while, which was the last version downloaded. I began working with this. However, when I return to work in the software it doesn't run and the start page appears with the word "Inicializing.."
Message 6 of 12
ingjuan_mena
Still doesn't run version 2026.
Message 7 of 12
ingjuan_mena
Now, it's working.
Message 8 of 12
romain.bobinetRKMH7
There is an ongoing issue with the licensing module used in InfraWorks, which had been updated earlier this month. The team is aware of the incident and working on a fix.
Rgds,
Romain Bobinet
Message 9 of 12
ingjuan_mena
Thanks sir!
Message 10 of 12
edgar.rey
Thank you for your reply, @romain.bobinetRKMH7 . It is good to know about it.
Message 11 of 12
ian.robinsonUASMF
Do we have a fix yet?
Message 12 of 12
ingjuan_mena
I've read about a partial solution which consists in unistall the current version of asdk Licensing and install a version older.
