Infrastructure Part Shape Utilities plug-in for Autodesk Inventor
Message 1 of 33
  • According to this link, using the Infrastructure Part Shape Utilities plug-in for Autodesk Inventor 2017 Pro or LT can be create and configure .IPT parametric model files for use in InfraWorks bridge design.
  • I did exactly the same as above, but there is not "Infrastructure Part Shape Utilities plug-in".
  • I use Inventor 2018 and InfraWorks 2018 student version. Should I use Inventor 2017? Is it only for Inventor 2017?
Thank you in advance,
Ali
Replies (32)
Message 21 of 33
Peter.deVries
Hello every one,
Though this thread is marked as 'Solved', it is not solved for me - unfortunately.
I have installed Inventor Professional 2018.1 (build 171) and InfraWorks 2018.1 (version 18.1.36.0). However, the 'Infrastructure Part Shape Utilities' is not showing up in the Environments tab - despite un- and reinstalling InfraWorks. It did show up in Inventor 2017, but since it is 'integrated in InfraWorks 2018.1, I cannot seem to get it working in Inventor 2018.1.
Does anyone know how to fix this? I am running out of options, so any help would be great!
Peter de Vries
Message 22 of 33
Charlie.Ogden
Hi Peter,
In Programs and Features do you see either of these listed?:
  • Autodesk Inventor Infrastructure Modeler Plugin
  • Project Kameleon
If you do, please uninstall them and then the following folders, if they exist:
C:\Program Files\Autodesk\Project Kameleon
C:\ProgramData\Autodesk\Kameleon   (back this folder up first if you have anything custom in it)
Do you have any of these files on your computer?:
  • InfrastructurePartModeler.dll
  • Autodesk.InfrastructurePartModeler.Inventor.addin
Charlie Ogden, PE
Product Manager
Message 23 of 33
Peter.deVries
Hi Charlie,
Thank you so much for your reply!
Indeed, I had the Autodesk Inventor Infrastructure Modeler Plugin installed. So I did exactly as you wrote:
- uninstall the Autodesk Inventor Infrastructure Modeler Plugin
- delete C:\ProgramData\Autodesk\Kameleon
- delete C:\Users\Public\Documents\Autodesk\Kameleon
- delete C:\Users\<username>\Documents\Autodesk\Kameleon
I started Inventor, but unfortunately no 'Infrastructure Part Shape Utilities'...
But when I searched my computer, there was no 'InfrastructurePartModeler.dll' or 'Autodesk.InfrastructurePartModeler.Inventor.addin' available.
So I ran 'ShapeModeler.msi' from 'C:\Autodesk\Autodesk_InfraWorks_2018_1_Multilingual_Win_64bit_DLM\x64\ShapeModeler' and was very anxious if this would do the trick .........
YES, finally !
You made me happy 🙂 Thank you once more, Charlie.
Kind regards,
Peter
Message 24 of 33
Hi guys,
I have the same problem. I've uninstalled all of my Autodesk softwares and files, installed Inventor 2017 and then Infraworks 2019 and it didn't work!
I think Infraworks 2018 is no longer available, I could'nt find.
I thinking format my computer to try one more way to do it. I've been spending many days on that.
Have anyone tried to make this work with Infraworks 2019? Thanks.
Message 25 of 33
Hi Charlie,
I do have same issue and I don't have these two files below. Please help? Thank you!
Message 26 of 33
DarrenP
did you read the part about running the msi file?
read above replies on location
DarrenP
Message 27 of 33
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Anonymous ,
let me know if you need some older installation files (2017, 2018, etc.)
Karsten.
Karsten Saenger
Message 28 of 33
Hi everyone, I got it. I uninstalled all Infraworks versions and Inventor, then I installed first Inventor 2017 and then Infraworks 2019. On that way the part shape utilities has showed up.
Message 29 of 33
jamesmac1201
Im unable to find the plugin in Inventor LT 2019. I also have Infraworks 2019 installed. Any suggestions?
Message 30 of 33
DarrenP
have you tried the suggestions that were mentioned already?
was inventor lt installed first?
DarrenP
Message 31 of 33
jamesmac1201
Thanks for the reply. These are the steps i took prior to replying to your message:
1) Uninstalled Autodesk Infraworks
2) Reinstalled Autodesk Inventor LT 2019
3) Restarted computer
4) Installed Autodesk Infraworks
5) Restarted computer
6) Opened Inventor to see if the plug-in was installed. It is not.
Any suggestions?
This is the version of Inventor i have: Inventor LT 2019; 64-Bit; Build 136
This is the version of Infraworks i have: Infraworks 2019 version 19.0.84.0
I have not done any updates via Autodesk Desktop App as of yet.
Message 32 of 33
Charlie.Ogden
This is an old post originally based on 2017 and 2018 behavior.  For 2019 and 2020 the process is a little different. The add ons are not automatically installed anymore, but should now show up in the Autodesk Desktop App as available updates after installing InfraWorks or Civil 3D, and Inventor for the plugin. If you don't see them there, then go to manage.autodesk.com to download them (or check with your company's IT/CAD manager - or whomever has access to your Autodesk account).
Charlie Ogden, PE
Product Manager
Message 33 of 33
jamesmac1201
Thank you.
