Infrastructure Part Shape Utilities plug-in for Autodesk Inventor
Nicht anwendbar
5.664Aufrufe
32Antworten
Nachricht 1 von 33
Nicht anwendbar
  • According to this link, using the Infrastructure Part Shape Utilities plug-in for Autodesk Inventor 2017 Pro or LT can be create and configure .IPT parametric model files for use in InfraWorks bridge design.
  • I did exactly the same as above, but there is not "Infrastructure Part Shape Utilities plug-in".
  • I use Inventor 2018 and InfraWorks 2018 student version. Should I use Inventor 2017? Is it only for Inventor 2017?
Thank you in advance,
Ali
0 „Gefällt mir“-Angaben
Akzeptierte Lösungen (2)
5.665Aufrufe
32Antworten
Antworten (32)
Nachricht 2 von 33
DarrenP
yes this only works with Inventor 2017 for some reason
@Eric_Chappell can you confirm this only works for Inventor 2017?
DarrenP
Nachricht 3 von 33
Nicht anwendbar
@DarrenP Thank you very much for your answer.
Nachricht 4 von 33
Nicht anwendbar
I have Inventor 2017 installed.
it doesn't work with Inventor 2018 and Inventor 2017!!!
Nachricht 5 von 33
DarrenP
for inventor 2017 it shows up on mine
did you install in that order Inventor 2017 has to be installed first then install Infraworks 2018
if Infraworks 2018 was installed first the environment will not show up in Inventor 2017
DarrenP
Nachricht 6 von 33
scunningham
Inventor 2018 and 2017, both Pro and LT, are supported. We recommend installing Inventor first, before InfraWorks 2018.
Sarah Cunningham
Product Manager, Autodesk Takeoff
Nachricht 7 von 33
Nicht anwendbar
I have first Inventor 2017 installed then I have Infraworks 2018 installed. but it didn't work.
Finally i have decided all Autodesk softwares uninstalled after that again Inventor 2017 then Infraworks 2018.......
I must say that its worked out. 😉
Thank you so much,
Ali
Nachricht 8 von 33
Nicht anwendbar
I did the same. But I do not know exactly what was problem.
Fortunately it works in Inventor 2017 now. but in inventor 2018 doesn't work yet.
Thank you for your answer,
Ali
Nachricht 9 von 33
DarrenP
@scunningham can you confirm this?
i cannot get the environment to show in Inventor 2018 but it does show in Inventor 2017
the help says Inventor 2017 it does not say Inventor 2017 or higher
DarrenP
Nachricht 10 von 33
Nicht anwendbar
Could you give me the site where to download the ''Infrastructure Part Shape Utilities plug-in"?
Thanks !
Nachricht 11 von 33
Charlie.Ogden
Akzeptierte Lösung
The Part Shape utilities is not a separate download... it is part of the InfraWorks 2018 install. Install Inventor 2017 or Inventor 2017 LT first (not 2018 right now) and then install InfraWorks - during the install, if Inventor is found it will install the Part Shape utilities. If you ever had Project Kameleon installed, uninstall that first, and remove all associated files and folders.
However, if you have already installed InfraWorks first you can install Part Shape utilities using the Shape Modeler .msi file found where you extracted the InfraWorks installer (by default that is C:\Autodesk)... In the InfraWorks folder at the extracted location find the .msi file in the ...\x64\ShapeModeler folder.
Charlie Ogden, PE
Product Manager
Nachricht 12 von 33
Nicht anwendbar
Excuse me ,I have  installed Part Shape utilities ,but it doesn't change.I don't known why it is ?
Nachricht 13 von 33
DarrenP
what doesn't change?
DarrenP
Nachricht 14 von 33
Nicht anwendbar
Thanks for your suggestion,but when I uninstall both software ,then install Inventor2018 first before InfraWorks 2018, it doesn't work. Should I delete all the register licences of  both software, then  install them in the order that you have supposed?
Nachricht 15 von 33
Nicht anwendbar
Nachricht 16 von 33
Nicht anwendbar
 I  install InfraWorks 2018 first ,then Inventor 2018, after that I install Part Shape utilities using the Shape Modeler .msi file ,it doesn't work. how can  I do?
Nachricht 17 von 33
DarrenP
this doesn't work with Inventor 2018 yet this only works for Inventor or Inventor LT 2017
DarrenP
Nachricht 18 von 33
scunningham
Correct. (Sorry, I misstated earlier. Charlie's responses above are correct.)
Sarah Cunningham
Nachricht 19 von 33
DarrenP
Akzeptierte Lösung
with Infraworks 2018.1 The Part Shape utilities now works with Inventor 2018
DarrenP
Nachricht 20 von 33
khidihanhan
Community Visitor
Community Visitor
I have installed infraworks18.1 and inventor infrastructure plugin works in both 17 and 18. But when I click export template dialog box will not show and nothing happens.  could someone help me with it  please?屏幕截图(40).png
