Existing and Proposed Surface tie in points do not match
Paul.GrafPZAZ7
Paul.GrafPZAZ7
I have imported a Civil 3d model .IMX model into Infraworks and for some reason the surface & corridor do not match. What causes this? see Image below. Everything looks good in my Civil 3d model. I am using IW 2004.
ToddRogers-WPM
Did you use the existing surface from InfraWorks? Because the InfraWorks existing surface is way different in elevation. In other words, it's not very accurate.
Todd Rogers
Civil Administration at Walter P Moore
