Rotate all objects using data source
Karadzhaian_Eduard
Advisor Advisor
Message 1 of 11
Karadzhaian_Eduard
Hi all,
I want to add design lightpoles to my Infraworks model.
As an existing source data i use AutoCAD blocks, either of them have an individual rotation angle.
I try to import this data using GIS format (.sdf) - data completely have been added to Infraworks with standart rotation angle for all objects.
Next I want to automatically rotate all data objects using script:
But it doesn't work.
I'll be glad to get any advices ASAP.
Thanks in advance
Eduard Karadzhaian
Senior Civil Infrastructure Engineer
Blog| LinkedIn| E-mail| Youtube|
Replies (10)
Message 2 of 11
andrewofabley
@Karadzhaian_Eduard
If your SDF has a a rotation attribute on it, you can map that to the 'rotate z' field in the table view at import. No script required.
AEC Collection / Safe FME / ESRI ArcGIS / Unreal Engine
Digital Engineering Lead, Compulsive Problem Solver.
Message 3 of 11
Karadzhaian_Eduard
@andrewofabley could you please confirm this information using screenshot?
In 'rotate z' field it is impossible to input rotation attribute name or choose it from list. There is a possiblity to input only absolute values. Essentialy I have rotation attribute in my .sdf file.
Eduard Karadzhaian
Message 4 of 11
Karadzhaian_Eduard
Another situation with "Set elevation" value. Here there is a possibility to adjust any attributes values.
Eduard Karadzhaian
Message 5 of 11
Karadzhaian_Eduard
My problem solved.
Really script was so easy:
function Process(SOURCE, CITY_FURNITURE) {
CITY_FURNITURE.MODEL_ROTATE_Z = SOURCE["ATTRIBUTE_NAME"]*180/3.14;
return true;
Eduard Karadzhaian
Message 6 of 11
Karsten.Saenger
Autodesk Support
Autodesk Support
Hi @Karadzhaian_Eduard ,
just for answering the open question about where to define the rotation - if you have an attribiute in the SDF/SHP files for rotation, you can select it in the table tab:
Karsten.
Karsten Saenger
Message 7 of 11
inception2708
How to export object in Civil 3D with attributes, I use command MAPEXPORT but it no attributes, please help!
Message 8 of 11
mark.reeveTXANL
I try the above method and am still not getting the same rotation as in CAD. I have an SDF with extracted rotation values, I map that attribute (and convert from radians) but it is still a different rotation to the CAD. The value is the same but the angle is different.
Message 9 of 11
namlt33
Go to data tab, select "select attributes" chose the properties you want
Message 10 of 11
sconroy
Thanks for this - I know it's an old post, but it helps!
There's a couple of things I did differently in v2026 as the above didn't quite work for me as posted.
1. I entered the formula in the table tab rather than in the script tab as the latter didn't work
2. I corrected the rotation by subtracting 90deg due to the orientation from my export from AutoCAD.
Easy corrections to make!
Sean
Dell Precision 7740 Intel Core i9-9880H CPU @ 2.30Ghz -32GB RAM Windows 10 Pro - 64Bit
NVIDIA Quadro RTX4000 video card dual/dual monitor setup
Civil 3D 2019.3.4 w/ AutoCAD 2019.1.4 / Infraworks 26.0.0.16
Message 11 of 11
srksphillips
I’ve run into the same issue before, and it usually comes down to one (or both) of the following causes:
Model Orientation
The 3D model might not be facing the correct direction.
  • Try rotating the model so it aligns with the green axis (X-axis).
  • In my case, I had to rotate the model of the lighting column 180 degrees.
  • Important: Don’t rely on the ViewCube for orientation—it can be misleading.
Rotation Angle Direction
Your attribute values might assume clockwise rotation from North, but InfraWorks uses counter-clockwise rotation.
  • This means your lighting columns (or other features) may rotate, but not in the direction you expect.
  • To correct this, subtract your angle from 360:
    • For example: 360-[insert attribute name] e.g. 360-Bearing
  • My bearings are in degrees from North, not radians—so make sure your data matches that format.
Cheers,
Steve
