Drawing improvment
Drawing improvment
Hello!
I need to customize the BOM table with additional columns, such as note, weight or a custom properties.
At the same manner, i need to insert in the Title Block various properties such as material, heat treatment, color and so on.
Thanks in advance.
Ronny
5 Comments
mhoff67
+1 from me - and please also include the "Dimenson" e.g. Bounding box -  I use the https://apps.autodesk.com/FUSION/en/Detail/Index?id=2857656002406992603&appLang=en&os=Win64 at the moment - but a better build in BoM would be great
Telliria
The sketch team are for working on customizable title box and, I believe, also more expandable BOM.
Read more here: http://www.autodesk.com/products/fusion-360/blog/2d-drawings-check-roadmap/
mhoff67
Hy Axel thanks for pointing to the right roadmap.
If i look at the info there seems we will get some improvement soon.
The plan for the BoM is in this Mural if i understand right:
So to the features that I wish most are not "in progress"  or at the backlog.  At least  selecting Bom levels to display is very important.
(As woodworker I often need a cutting list with x/y dimensions of all parts)
Greetings from Heidelberg - Michael
keqingsong
Status changed to: オートデスク審査落選
Telliria
That's a great idea, I didn't read the "to display" part first, but that would be excellent indeed.
Good to see this got accepted @keqingsong, thanks for the work you do on improving our favourite software!
