HSM Post Processor Forum
Question to understanding turning I-J-K-Values
5 REPLIES 5
makko74
768 Views, 5 Replies
yesterday i've made 3 little nc-programs for a friendly company.
My first simple turning Parts with HSM. 😄
For the Post-Process i've used the fanuc turning.cps.
Now my question:
on milling I,J,K values are incremental from arc-start to centerpoint.
in the fanuc turning.cps stands:
var xFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:2}); // diameter mode
and for I and K outputs
// circular output
var kOutput = createReferenceVariable({prefix:"K"}, xFormat);
var iOutput = createReferenceVariable({prefix:"I"}, xFormat); // no scaling
Is this normal thats I- and K-Values must also scale with 2 on turning?
Thank you in advance
InfoInventor CAM(Ultimate) user --- Inventor Professional 2021.2 + Inventor CAM Ultimate 8.1.2.21785
5 REPLIES 5
skidsolo
in reply to: makko74
Some machines can be programmed with either diameter or radius values for X. It can be changed by a machine parameter in the controller to suit the users preference. The Haas turning post is does not have scaled IJK. So the answer is they are different.
http://forums.ge-ip.com/showthread.php?t=14635
Andrew W. Software engineer (CAM Post Processors)
makko74
OK, and the effects are also on I and K Values. Right?
Thank you Andrew
Thank you Andrew
The way the k&iOutputs are set-up here means are scaled like the X-value. So if X is scaled to diameter mode the k&i will be too.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
makko74
Laurens-3DTechDraw wrote:
Thank you Andrew
It was just incomprehensible to me thats the K -Values must also entered in diameter mode.
Now its a little bit clearer, i've no Lathe and the machinist is up to next week on vacation,
so i'm asking here.
Thank you for your time and answers Laurens and Andrew
so i'm asking here.
Works like a charm on our Fanuc machine. 😉
Laurens Wijnschenk
3DTechDraw
René for Legend.
Technology Administrators
