Solved by Laurens-3DTechDraw. Go to Solution.
Solved by skidsolo. Go to Solution.
AndrewWard wrote:
Some machines can be programmed with either diameter or radius values for X. It can be changed by a machine parameter in the controller to suit the users preference.
makko wrote:
OK, and the effects are also on I and K Values. Right?
Thank you Andrew
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Laurens-3DTechDraw wrote:
Thank you Andrew
The way the k&iOutputs are set-up here means are scaled like the X-value. So if X is scaled to diameter mode the k&i will be too.
makko wrote:
It was just incomprehensible to me thats the K -Values must also entered in diameter mode.
Now its a little bit clearer, i've no Lathe and the machinist is up to next week on vacation,
so i'm asking here.
Thank you for your time and answers Laurens and Andrew
Laurens Wijnschenk
3DTechDraw
René for Legend.
