HSM Post Processor Forum
Post for Deckle Maho DMU 70 eVolution 5axis ??
7 REPLIES 7
Message 1 of 8
3839 Views, 7 Replies
Hi I have a 2 DMG machines with the Heidenhain TNC 426/430pb controllers.
DMU 70 evo  &  DMU 50 t ( this is a 3 cnc 2 manual axis but it still can use cycle 19 )
I already have 2 good cam solutions but I am interested to try HSM form inside Solidworks as we design everything using SW.
Has anyone got a post they are willing to share.  Even if it needs tweaking I may be able to help with that as I have been 5 axis machining for 18 years now.
Any help will be appreciated.
Thanks in advance.
Robbie
7 REPLIES 7
Message 2 of 8
Laurens-3DTechDraw
Rob, I'm pretty sure there are posts for this.
The Post-team of Autodesk CAM, will help you.
Any tweaking I can help again.
Will probably be Monday or Tuesday, they will react on this.
But don't pin me down on this.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 3 of 8
Hi Thanks for your reply.  As I have said at this time I only want to test the SW out so I am not in a rush.
Thanks for replying.  And thanks for the offer to help with the post.
Robbie
Message 4 of 8
skidsolo
Hi there these posts are from our library, please check carefully.
Andrew W. Software engineer (CAM Post Processors)
Message 5 of 8
in reply to: skidsolo
Hello.
I have problem, mashine is DeckelMaho DMU 50v, B-axis table rotate under 45 degrees. Control is MillPlus v330, without G07 g-code.
Can You help me to solve this problem.
Message 6 of 8
Hello
I'm also looking for a processor post for DMU 50 - 5ax continuous with sinumerik 840 D (CELOS)
Who can help me ???
emaill: marius_micromet@yahoo.com
Message 7 of 8
@marius_micromet wrote:
Hello
Who can help me ???
The generic Siemens 840 D should just run if you setup the machine configuration properly.
https://cam.autodesk.com/hsmposts?p=siemens-840d
Laurens Wijnschenk
3DTechDraw
René for Legend.
Message 8 of 8
ddkwonGZBER
thank you
Have a nice day
