Hello.
I just started posting fusion 360 posts to an old Abene VHF mill. I
Hi @Anonymous
That should already be built in to the post.
Tick or check the HomeXY at end properties
You have some options, you can:
a) Configure a machine in Fusion or HSM with the X 0 Y0 and Z100 as the home position
or
b) In the post @ line 200 remove the block comment and add the values you want
change this:
// NOTE: setup your home positions here
machineConfiguration.setRetractPlane(-20.415); // home position Z
machineConfiguration.setHomePositionX(-200); // home position X
machineConfiguration.setHomePositionY(-5); // home position Y
to this:
machineConfiguration.setRetractPlane(100); // home position Z
machineConfiguration.setHomePositionX(0); // home position X
machineConfiguration.setHomePositionY(0); // home position Y
