HSM Post Processor Forum
post to fagor 8050 milling
7 REPLIES 7
Message 1 of 8
1276 Views, 7 Replies
There is a post that wirk well whit a milling working with fagor 8050?
7 REPLIES 7
Message 2 of 8
KrupalVala
Hi @Anonymous ,
We have a post processor for the FAGOR 8037/8055 and it has Milling capabilities. You can download the post processor from here.
Thank you.
Krupal Vala
Senior Technology Consultant - Post Processor & Machine Simulation
Message 3 of 8
in reply to: KrupalVala
Thak you very much. I'll try it.
Thanks again, Javier
Message 4 of 8
I try but I have the error that appears in the attached image
Message 5 of 8
KrupalVala
Hi @Anonymous ,
I'm not sure whether you are getting this error through NC code, out of the limits defined by axis parameters or PLC.
Krupal Vala
Message 6 of 8
The mistake was in the machine 0,0,0.
But now I have new issues.
I have 2 messages showed at images attached.
Can you help me please??
Message 7 of 8
KrupalVala
Hi @Anonymous ,
1) ERROR 1084 : arc error from controller.
Please turn-on G16 option in your post from
  useG16: false, // use G16 instead of G17/G18/G19
to
useG16: true, // use G16 instead of G17/G18/G19
2) Error 0002  Improper data Error : When programming a block number greater than 9999
If you still getting an error then turn off sequence number.
I hope this helps, but please let me know if you need anything else.
Krupal Vala
Message 8 of 8
Hi!!
The changes work well. Jai ho!!
Thank you very much!!
