HSM Post Processor Forum
Heidenhain TNC 155 post customization help.
1 REPLY 1
492 Views, 1 Reply
Hello.
I just started posting fusion 360 posts to an old Abene VHF mill.
I
 would like to customize a few things but I can't seem to fix it myself.
First thing is that i would like to change the M91/M92 positioning to "X0 Y0 Z100." instead.
Second thing is that in the start of each operation it wants to position to "Z0" before going to starting positions.
Example:
"0 BEGIN PGM 1002 MM
1 BLK FORM 0.1 Z X-300 Y-55 Z-52
2 BLK FORM 0.2 X+300 Y+10 Z+13
3 TOOL DEF 1 L0 R+25
4 L Z+0 R0 F9998 M91
5 M5
6 TOOL CALL 1 Z S1400
7 M3
8 L X-327.5 Y+1.685 R0 F9998
9 L Z+28 R0 F9998
10 L Z+18 F9998
11 L Z+10.5 F700"
Hopefully someone can help me out with these things.
Thanks in advance.
Labels (3)
1 REPLY 1
patrik_stellgren
Hi @Anonymous
That should already be built in to the post.
Tick or check the  HomeXY at end properties
You have some options,  you can:
  a) Configure a machine in Fusion or HSM with the X 0 Y0 and Z100 as the home position
or
 b) In the post @ line 200    remove the block comment and add the values you want
change this:
  // NOTE: setup your home positions here
  machineConfiguration.setRetractPlane(-20.415); // home position Z
  machineConfiguration.setHomePositionX(-200); // home position X
  machineConfiguration.setHomePositionY(-5); // home position Y
to this:
  machineConfiguration.setRetractPlane(100); // home position Z
  machineConfiguration.setHomePositionX(0); // home position X
  machineConfiguration.setHomePositionY(0); // home position Y
Technology Administrators
