HSM Post Processor Forum
G43.5 ERROR - My machine doesn't recognize the G-Code
2 REPLIES 2
Fabbunny69
432 Views, 2 Replies
I am setting/testing my post for 4-Axis jobs and it does not recognize G43.5
The machine has a 4th rotary axis(A-Axis) about the X-Axis and everything seems to be fine in the program outputs now apart from this, do I need G43.5? And if not how do I get rid of it?
2 REPLIES 2
Hi @Fabbunny69
I think you are using a highly outdated post. I would suggest you to download the latest Fanuc with A axis from the library  https://cam.autodesk.com/hsmposts?p=fanuc_with_a-axis
this will output codes as you expected
Boopathi Sivakumar
Senior Technology Consultant
Thanks once again @boopathi.sivakumar
Would have helped myself if I would have started off with the correct post in the beginning 😞
Technology Administrators
