3+1 Post Processor In need
Hi who has post processor 3+1 Fanuc Control 31i with g68 code as plane spatial , Axis of rotation  "X"
boopathi.sivakumar
Hi @Anonymous
I am not sure what you want here! is it G68 or G68.2?
G68 is Coordinate rotation nothing to do with Plane rotation if it is G68.2 then you can use the standard Fanuc post which has the 68.2 enabled by default.
Probably you might want to change the Euler method to match as per your machine Euler
Boopathi Sivakumar
Senior Technology Consultant
Hi Boopathi. sivakumar,
on our machine builder we don't have this option G82.2
Yes we want to change the Euler method to match as per your machine Euler.
Please refer to sample NC output below:
Drilling sample
[image: image.png]
OO37001
(CSYS X-0.002526Y33.553400Z0.000000A23.000000)
G10G90L2P0X0.Y0.Z0.A0.
M05
M09
M11
M01
M22
G54G90G00A23.
M21
M01
N0001
T09M06(DIA-3.5-DRILL)
G54G90G00S1000M03
G68G90X0.Y0.R0.
G00X-5.537Y-.002
G43H09Z20.521
M08
G81G98X-5.537Y-.002Z-13.847R-.847F250.
G80
G69
M05
M09
G28G91Z0.
G28G91Y0.
N0002
T10M06(DIA-4.0-DRILL)
G54G90G00S796M03
G68G90X0.Y0.R0.
G00X-5.537Y-.002
G43H10Z20.521
M08
G81G98X-5.537Y-.002Z-33.847R-.847F250.
G80
G69
M05
M09
G28G91Z0.
G28G91Y0.
M30
above this line -##
boopathi.sivakumar
In that case I think you can use Fanuc with A axis post that will get you the codes as expected
https://cam.autodesk.com/hsmposts?p=fanuc_with_a-axis
Boopathi Sivakumar
thanks for the input and shared pp I think  the PP you share will do.
thank you so much.
