Show only
Search instead for
Separate Avoid/Touch Surfaces in Finished Operations
Currently you have to pick one or the other. It would be very helpful in some cases to be able to select touch surfaces and also select surfaces to avoid within the same operation.
It's very strange that you can only select OR avoid an area in the same operation. We have had many scenarios where we need a bit of each! +1 to this suggestion!
