Separate Avoid/Touch Surfaces in Finished Operations
Currently you have to pick one or the other.  It would be very helpful in some cases to be able to select touch surfaces and also select surfaces to avoid within the same operation.
8 Comments
ivan.stanojevic
Tottaly agree to that
narzinskin
The title should read "finishing" operations, not "finished".  Monday morningsSmiley Sad
timsautodesk2015
AGREE!!!!
dblack
I was just thinking the same thing the other day. Definitely a need. This one has my vote!
dave.bruford
It's very strange that you can only select OR avoid an area in the same operation.  We have had many scenarios where we need a bit of each!  +1 to this suggestion!
martin.walter
Indeed, this makes sense! Running into this limitation a lot as soon as 3D parts are a bit more complicated.
CNCfacile
Maybe is time to implement this feature!!!!
sergio.otegui
needing this....my Y2k cimatron has it
