Hi
I have Turkish.xml language file. I enter Translations section,I open this xml file and update , I close Inventor HSM and open it again.But the Language is not change.
How can I fix it? or Is there another way?
Best regards,
Solved by meletis.stathis. Go to Solution.
I have pinged development to see if things have changed in how to do this.
I changed name to "turkish_tr" and language in options in CAM tab.I reopened Inventor. Language is changed.
Thank you
Hi
What about spanish translation of fusion 360
Any idea if there is a spanish version?
If not, how can I translate it myself?
When downloading fusion 360, which file is the one that I have to translate?
Thank you
Hi @fst,
Thanks for offering help to translate Fusion360 to spanish yourself. Unfortunately, this thread was created for the turkish translation in InventorHSM.
Maybe you can ask about translation plans and get some help to that thread:
http://forums.autodesk.com/t5/design-validate-document/fusion-360-menu-language-settings/td-p/478180...
