Fusion Support
very low fps. like 10 fps or something
2 REPLIES 2
napelazam
167 Views, 2 Replies
https://www.youtube.com/watch?v=L1lEI5MZJ0E
https://www.youtube.com/watch?v=JvF7ccK09hQ
mouse cursor is fine. no big lag input.
but hell.... when u actually move things around in 360.. oh my.... soo annoying
here just an example of clicking on top on the cube or whatever and look how the fps drops to 10.. so disgusting. when i manually turn camera fps is fine, just not via the cube there.
i am the last person on earth who would say that there is a relevant difference between 60 and 120 fps, just saying. the different is very much neglectable.
but f360.... uphhh
2 REPLIES 2
nkloski
in reply to: napelazam
I would suggest you look at the other thread and see if oyu have the same problem as I (and others) do:
https://forums.autodesk.com/t5/fusion-360-support/stuttering-and-freezing-slow-performance-since-las...
...the problems evident in that forum post also extend out to moving the window, like what you showed in your screen recorder video.  If you have those same problems as we talk about in that thread, please add to that thread so the problem gets more attention.  I have definitely seen the problem discussed in that thread extend out to grabbing and moving the entire application window, so hopefully it is the same problem and the dev team can address all of our concerns at once.
Nick Kloski
napelazam
in reply to: nkloski
do you not see how clicking on "front" of the cube leads to low fps?
Technology Administrators
