05:24 AM
I need a little help. I´m just elementary in Fusion, so I belive, that will not be so though.
I have an object made of two parts (Bottom, Top). I´ve created the Top part by Revolve function, so it has different
atributes than the Bottom part. Now, I need to combine these two parts together, but I ´m not able to select the Top part. I need them to be together due to the cutting that I´d like to perform with them (Make a "negative" form in cylidrical shape).
Thank you very much for you help
Kevin
