Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Unification of the objects
3 REPLIES 3
241 Views, 3 Replies
I need a little help. I´m just elementary in Fusion, so I belive, that will not be so though.
I have an object made of two parts (Bottom, Top). I´ve created the Top part by Revolve function, so it has different
atributes than the Bottom part. Now, I need to combine these two parts together, but I ´m not able to select the Top part. I need them to be together due to the cutting that I´d like to perform with them (Make a "negative" form in cylidrical shape).
Thank you very much for you help
Kevin
Tags (2)
Labels (1)
3 REPLIES 3
jeff_strater
your "top" is a surface body, and your "bottom" is a solid body.  You need both to be solid to use Combine to join them.  Be sure you use commands from the Solid tab:
Jeff Strater
Engineering Director
in reply to: jeff_strater
Thank you, very much!
Now I see what to do. I applied the Stitch function on the surface body and now I´m able to perform what I need to.
Have a nice day!
Kevin
g-andresen
Please mark contributions that made a solution by checking them as "Accepted Solution".
This will make it easier for future readers.
günther
