I want to delete this file but when I validate the deletion I have an error message which appears telling me that this is not possible because the file is used, but this is not the case. Is this normal? how to remove it?
Solved by g-andresen. Go to Solution.
You are welcome!
John Hackney, Retired
@mac_ito Data management especially on the delete side has been not the best user experience from Fusion. I have made this thread visible again to the engineering team.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
