Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Unable to delete file
5 REPLIES 5
mac_ito
322 Views, 5 Replies
I want to delete this file but when I validate the deletion I have an error message which appears telling me that this is not possible because the file is used, but this is not the case. Is this normal? how to remove it?
Capture d’écran 2024-03-17 à 08.23.02.pngCapture d’écran 2024-03-17 à 08.23.32.pngCapture d’écran 2024-03-17 à 08.23.37.pngCapture d’écran 2024-03-17 à 08.23.43.png
5 REPLIES 5
g-andresen
in reply to: mac_ito
follow this tutorial  by @jhackney1972
günther
mac_ito
in reply to: g-andresen
perfect! Thanks @g-andresen
jhackney1972
You are welcome!
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
mac_ito
in reply to: jhackney1972
thanks a lot @jhackney1972
@mac_ito Data management especially on the delete side has been not the best user experience from Fusion. I have made this thread visible again to the engineering team.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
