My toolbar suddenly black out when I opened it. I was able to use the software fine until I reopened it and the toolbar blacked out. I have tried uninstalling and reinstalling but the issue is still there.
Here is a screenshot for further detail. I can still click the functions of the toolbar and everything works but the toolbar is blacked out.
Solved by lance.carocci. Go to Solution.
Solved by dsouzasujay. Go to Solution.
i have tried all the solutions listed above, there is error window pops up, saying not found, reinstalling will solve your problem.
Hi @beatNXAMS @Anonymous @info1234567891234567890123 @Anonymous @Anonymous
The latest Fusion 360 Update has the fix, Build number 2.0.10148.(You may need to restart Fusion 360 to see Auto-Update)
Note: After Fusion 360 updated to build 2.0.10148 version, then you can clear the environment variables.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souzaHi @Anonymous @Anonymous @beatNXAMS @info1234567891234567890123 @Anonymous
Note: After Fusion 360 updated to build 2.0.10148 version, you can clear the environment variables.
Sujay D'souzaHi @dsouzasujay
I got it!
The problem for me was that my main Windows 10 user account does not have administrator privileges, so that when I would go to Advanced system settings from (Control Panel > System and Security > System) I had to enter administrator credentials, and when I changed Environment Variables, they were changed for the administrator user account only.
The solution for me was to go through (Control Panel > User Accounts > User Accounts) while logged into my main (non-admin) user account, click on "Change my environment variables". Then I followed instructions to add environment variable QT_OPENGL with value "angle" for my main user account.
Thanks!
